| Message |
I verified compression on #2 only when i said i had compression. At 100 psi, i assumed lack of lubrication and lack of being broken in, it would increase. You are correct, a timing belt check is next on the list, but you forgot about a possible lifter malfunction. If one or some of the lifters are stuck open, It wont allow the valve to fully close.
